Hi,
Is there a way to use avisynth plugins/filters within virtualdub? Like a .vdf plugin?
How do i make an .avs script for a avisynth plugin to use in virtualdub?
Write the AVS script.
See http://avisynth.org/mediawiki/Getting_started
http://www.theregister.co.uk/2009/06/25/beginners_guide_avisynth/
http://atlas.kennesaw.edu/~dhirschl/avisynth.html
Then open it with VDub from its file menu.Last edited by AlanHK; 5th Jan 2011 at 03:07.
To add to the above answers and to avoid any misunderstanding:
You cannot directly use an Avisynth plugin as a filter within VirtualDub.
What you can do is use an Avisynth script as the input file to VDub.
In that script you would use Avisynth commands to open your original video file and apply the Avisynth plugin to it.
VirtualDub will not know anything about the plugin - it will not show up in the list of filters and you cannot put other VDub filters before it in the filter chain.
Order for filters in Avisynth on Virtualdub!!
By Cauptain in forum Video ConversionReplies: 10Last Post: 4th Jun 2011, 14:29 -
Virtualdub filters in avisynth-faster? How to use them?
By salidarius in forum EditingReplies: 10Last Post: 3rd Mar 2011, 21:13 -
VirtualDub Plugins
By gazza67 in forum Newbie / General discussionsReplies: 6Last Post: 12th Dec 2009, 08:50 -
Basic question about AVISynth plugins
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2008, 11:04 -
How to install plugins for Avisynth?
By 1gnition in forum Capturing and VCRReplies: 4Last Post: 19th May 2007, 19:06
