Hi guys...I got a big problem here.I've done so much dvd ripping and one of my favourite setting is encode to x264 codec and make it in HD 720p size. For me, encoding HD 720p is not an issue because I'm just altering the codec, bitrate and avisynth scripts. I've used many applications like HandBrake, Format Factory, Avidemux, Mkvmerge, MEGui, Auto Gordian Knot, Virtual Dub and so on..But...I really cannot encode it to HD 1080p size..I really love that resolution, in order to makes me satisfied with the High Definition experience while watching movie/video
. Just tell me is there anybody who didn't like watching movie with full resolution, no border and extra clear picture? Hope you guys can help me....
DVD native resolution is 720x480/576. Upscale isn't going to add any resolution. Most are happy to let the player or display card handle the upscale.
http://www.kiva.org/about -
It's almost certainly a complete waste of time. As edDV said, let the player of display card do the upscaling.
As others have pointed out, unless your player or HDTV have very poor upscalers, there's no reason to upscale before encoding. Also keep in mind that whatever artifacts your upscaling creates will be locked into your video for all time. Whereas in the future you may get a player or HDTV with better upscaling than your current software technique and all your non-upscaled videos will look better.
But I'm curious, if you can change the AVS script to resize to 1280x720, why can't you change it to resize to 1920x1080?Last edited by jagabo; 4th Jan 2011 at 17:13.
How Can I Convert 1080p to 720p H.264 Encoded Video?
By channelz28 in forum Video ConversionReplies: 7Last Post: 6th Sep 2013, 11:44 -
Convert 1080P to 720P using Handbrake !
By augustya in forum Video ConversionReplies: 24Last Post: 11th Oct 2011, 04:53 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
Convert 1080p to 720p with DTS conversion to AC3
By El Duderino in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2010, 08:32 -
How to convert DVD to mkv with 720P or higher resolution
By dharmesh13 in forum DVD RippingReplies: 2Last Post: 21st Apr 2009, 19:47
