The problem is:
I have a 43gb iso file that contains a bluray movie.
I am trying to extract the movie back into bluray format.
Then use bdrebuilder to shrink the movie back down under 25gb.
Then use imgburn to burn to bluray media-(yes verbatim)
The question is how do I extract the movie out of the iso?
I tried Daemon Tools, Slysoft Virtual Clone Drive and isobuster
none of which worked.
The iso plays fine on powerdvd.
Any suggestions will be appreciated.
Using windows 7 ultimate 64 bit
for dvd i use to mount using daemon then would extract from the virtual drive with dvddecrypter but for bluray i'd try mount then use dvdfab or anydvdhd
What happens when you use virtual clonedrive? You can also try DVDFab Virtual Drive.
baldrick,
When I loaded the iso into virtual clone drive nothing happened. After several tries I downloaded and installed a fresh copy of virtual clone drive and then it worked ok. Thanks for steering me in the right direction.
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 13:39 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 11:29 -
How to re-author back to bluray from BDMV bluray structure?
By eummagic in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Dec 2010, 21:14 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05 -
ISO of a BluRay?
By ajgoyt in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Jun 2010, 02:02
