Hi guys,
i have some trouble with my LaCie Lacinema (hard disk + media player).
I was trying to view some photos using a USB flash drive and in order to maximize the resolution i chose from the Lacie menu the 1080p resolution which is not supported by my TV. Since then whenever i open the Lacie Lacinema the message "not supported" keeps coming on and i cant enter the Lacie browser menu in order to change the resolution to 768 and make the bloody thing play again...
Can someone please help???
Does it have a composite output? That may still be working and would always output standard definition.
jagabo THANKS A LOT
That worked perfectly and was able to restore the resolution back to 720p
THANK YOU
Problems with Lacie Lacinema Classic
By otinimeg in forum Newbie / General discussionsReplies: 21Last Post: 12th Mar 2011, 18:44 -
lacie lacinema premier 750GB
By east55 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Sep 2010, 02:58 -
Lacie lacinema HD dts sound problem
By alpedrinha in forum Media Center PC / MediaCentersReplies: 1Last Post: 19th Mar 2010, 18:52 -
Lacie LACinema Classic HD - 1T
By AN11211 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 12:25 -
LaCie LaCinema not playing all files correctly - Audio is off
By jhall_830 in forum Newbie / General discussionsReplies: 17Last Post: 14th Feb 2010, 06:35
