Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Closed Thread
    Jan 2011
    Bangladesh
    I have converted ts video 1920x1080pixel into mp4 using handbrake, I kept bit rate unchanged and constant ratio 22 and anamorphic strict but still some player cannot play only splash player pro can play.Should I change the bit rate or what should i do to play it with other player?
    what should be the best format mkv or mp4 in terms of output quality?
    best resolution preset ? 1360x768 which is the specification of my monitor or 1920x1080 the original ts specification.I mean should i keep anamorphic strict or something else ? if something else then plz answer with data.
    Does a video of 1920x1080pixel look blur in 1360x768 monitor bcz the monitor lacks the pixel? plz naswer
    thanks in advance
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How many threads are you going to make on the same exact subject?
    Jan 2011
    Bangladesh
    i make bcz nobody comes up with a answer i really rely on.
    Please stop make new similar threads. Just reply in your other threads....but wait some days before you bump it.
