Do I need to get a particular ATSC TV tuner/capture device to capture the 5.1 surround sound signal that is broadcast on some digital TV programs? For example, will a Hauppauge 1196 WinTV HVR-1250 card pass through the 5.1 audio or convert it to stereo?
With any of the current ATSC tuner cards, the ATSC broadcast's MPEG-2 transport stream is captured as is when using the ATSC tuner on the card. No audio or video conversion takes place. The container may differ, depending on the PVR software used, but what's inside it will be exactly what was received off the air.
Normally an ASTC tuner tunes the broadcast by channel and subchannel, then saves the program stream as sent including the associated AC3 audio. There is no stream processing other than choosing a video and audio PID from the multiplex.
Note that many ATSC channels broadcast several subs (e.g. 2-1 2-2, 2-3) as separate PID.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
TV TUNER CARD "ViXS PureTV-U 480B0 (NTSC/ATSC)" HP Desktops ?
By sonomablue in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2022, 17:56 -
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Diamond TV Wonder 650 Theater PCI-E TV Tuner Card ATSC NTSC HDTV FM with Rogers.
By Cabal2000 in forum DVB / IPTVReplies: 3Last Post: 25th Feb 2010, 21:18 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Dumping Comcast, looking for ATSC tuner card.
By gadgetguy in forum DVB / IPTVReplies: 25Last Post: 27th Jul 2008, 18:10
