Component wont output to my Apex TV. (Yes its hooked up correctly), I tried same setup on another TV using same component wires and works on the other TV. Any idea why its not on this one?
Results 1 to 10 of 10
Are you sending 480i ?
http://www.kiva.org/about -
its on auto, i didn't really think that would make a difference since im using the component cables, i guess i could try that.
The regular video output works fine... -
thanks i put it to 480i and works now. I didnt think that would make a diff thanks!
so im looking for hdmi cables i see they have net jack or silver plated at monoprice which shall i get?
ok
netjacket
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024004&p_id=...seq=1&format=2
silverplated
ferrite cores? what do they do block interference i assume by price they arent as good?
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024008&p_id=...t=1#largeimage -
I'd go with the silver plated but any will work.
But 24 gauge is going to be stiff, intended for inside wall runs.
28 gauge is more flexible and fine for short lengths (<15 ft) but higher loss in long runs.
Net Jacket refers to cable outer cover.
Ferrite cores are intended to block RF interference.Recommends: Kiva.org - Loans that change lives.
tv out(dvi to component) problem
By tseizaL in forum DVB / IPTVReplies: 30Last Post: 25th Dec 2009, 09:22 -
Component hookup to TV problem
By Noahtuck in forum ComputerReplies: 7Last Post: 20th Oct 2009, 19:03 -
Samsung SyncMaster 940mw TV - component cable image problem
By Joe88 in forum DVB / IPTVReplies: 2Last Post: 17th May 2008, 16:01 -
problem creating my own component cables.
By nick101181 in forum Newbie / General discussionsReplies: 10Last Post: 2nd Oct 2007, 14:13 -
Component video signal->TV problem
By nathanaa in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2007, 22:37
