If you were going to build a machine that would be a nice machine for doing some AVCHD video editing what would you suggest? This is kind of a survey I guess as to what would you put in it? Budget is around $2000
You're putting the cart before the horse. First, decide what editing program you are going to use, then check out the manufacturer's recommended hardware (usually under a System Requirements heading). Also scan user forums about any potential hardware issues that may crop up with the editing software you'll be using. You'll save yourself lots of headaches if you get informed as much as possible about the specific editor you'll be using.
Building a Batch Conversion Machine
By dj4monie in forum DVD RippingReplies: 11Last Post: 3rd Jun 2011, 23:29 -
Building a PC for Video Editing/Encoding - Need Advice plz!
By MaTTuP in forum ComputerReplies: 9Last Post: 6th Nov 2010, 11:37 -
Help: Building Computer for HD Video Editing
By Rantlers in forum ComputerReplies: 25Last Post: 2nd Apr 2010, 11:52 -
Machine Building Strategies
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2008, 14:37 -
Building A Video-Editing PC (slightly off topic)
By GrayStrickland in forum Media Center PC / MediaCentersReplies: 4Last Post: 26th Feb 2008, 14:39
