Hey guys, so I use AVCHD discs for HD playback on my Panasonic Blu-ray player. But I have a 12 GB MKV file I want to put on 3 DVDs. I tried splitting the MKV into 3 files using MKVtoolnix and then using multiAVCHD to convert it to AVCHD. Unfortunately, after I split the file and try to convert it, AVCHD immediately gives me an error saying "tsMuxer has stopped working." Now it doesn't give me an error when trying to convert the original 12 GB MKV file, so obviously the splitting is causing problems. So is there a way to burn AVCHD to multiple discs? Or is there another way I can solve this problem? Thanks!
Try other similar tools https://www.videohelp.com/tools/sections/all-in-one-mkv-to-mp4-avchd-ts
Just tried mkv2vob and AVCHDCoder and had the exact same problem with those. I'll keep trying to other ones, but I'm not optimistic. Anything else I can do?
Edit: just tried BDtoAVCHD and it wants to reencode the files for some reason, so that one's a no-go as well.Last edited by hiimbored; 2nd Jan 2011 at 16:34. Reason: Updated
Just found this quick workaround that fixed the problem http://www.avforums.com/forums/ps3-media-streaming/1303003-problems-mkv2vob-workaround-fix.html. I guess it's just a problem with the newest versions of MKVtoolnix.
Yep, the mkv compressed headers cause a lot problems.
Help Please- multiple AVCHD to DVD
By Lilygrace in forum Newbie / General discussionsReplies: 10Last Post: 21st Sep 2010, 07:44 -
Is there a graphical way to resize thumbnails in multiavchd for avchd discs
By yoda313 in forum Authoring (Blu-ray)Replies: 7Last Post: 26th Jun 2010, 21:20 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
avchd discs plays at 480p on ps3
By sitlet in forum Authoring (Blu-ray)Replies: 0Last Post: 30th Jan 2010, 21:49 -
Creating High Def (AVCHD) Discs on a Mac?
By ehmjay in forum MacReplies: 0Last Post: 14th Nov 2009, 23:11
