First I have read the other post but still cant get the audio to show up in TMPGEnc. I have tried Nimo codec pack and checked ac3 decoder but when I install this the audio still does'nt show up? can someone please take me through this
You need to give the direcshow filters the highest priority, 2 will be great! yov'll fins it under settings-> envirment settings
frotsen: yep it also worked and it is a bit simplier than demulitplexing...I will add it to the tmpgenc guide.
That worked
, but now the sound is alittle faster than the video, any advice? Almost there.
You may wanna try to things:
1. install intervideo direcshow audio filter, in Nimo codex pack. And encode the sound once more.
2: Use BBmpeg to multiplex, and delay the sound.(only if it's constant out of sync).
hope it helps
Converting the audio of an .mkv from AC3 to AAC
By Anonymous4453 in forum Video ConversionReplies: 9Last Post: 13th Nov 2011, 11:39 -
Converting AAC to AC3 (for DVD authoring), losing audio
By senorroboto2k5 in forum AudioReplies: 3Last Post: 16th Feb 2010, 19:03 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 21:28 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 14:27 -
Losing audio data converting AC3 to MP3, Help!
By blueprint in forum AudioReplies: 8Last Post: 24th May 2007, 15:55
