    Jan 2007
    Italy
    Is it possibile to view VD output in full screen? I'm using a side-by-side to anaglyph filter, but the output is good only "live", if I save it into an AVI I don't get same results, and viewing a full movie inside VD is really annoying!!
    -- Jumpjack --
  2. I don't think there's any way to get full screen output like with a media player. The closest you can get is to reverse the input and output panes (View -> Swap input/output panes), maximize the window, then right click on the output pane and select a zoom level.
    Jan 2007
    Italy
    it doesn't even work by frameserving to another application.Simply because I can't get frame serving working, although I read several tutorials, installed the client, restarted the PC, tried with the proxy mode...Is anybody of you able to use VD as a frame server for, say, VLC or Media Player Classic? With which options?!'
    -- Jumpjack --
  4. I don't have problems using the frame server. But I haven't seen to work to a media player.
    Try opening your VDR file in another instance of VirtualDub to test the frameserving.
    Jan 2007
    Italy
    Yes, VD "frameserves" to another instance of itself very well...
    Very useful.
    -- Jumpjack --
  6. At least you've verified that the frameserver mechanism is working. Not all programs accept frameserving.
