I have a JVC GZ-HD30 and shoot in full HD (MPEG2TS) creating .TOD files.
I have previously used Adobe PE 7 but now having bought a new iMac I am keen to use iMovie.
There are loads of topics / forum posts / blogs on the subject but none that gives a clear mechanism for importing .TOD files into iMovie without losing HD quality.
I have Mpeg Streamclip and the Apple component (cost £15 - a bit of a cheek) but the work round involves an actual file conversion which seems unnecessary as .TOD is just a wrapper.
So... I am about to upgrade to iLife 11 and the questions are...
1. Does iMovie 11 support 'virgin' importing of .TOD files and, if not...
2. Please can you give me a clear route to get those raw .TOD files into iMovie 9 or 11.
btw - I can use Mpeg Streamclip to demux to the m2v and accompanying audio file which easily imports into Final Cut Express but... I want to use iMovie 11 as it's easier to use for a novice like me...
".TOD" is to confuse newbys into thinking they need the accompanying JVC software which is probably a teaser program that prompts you to buy a full version of some crappy software.
a TOD file is an HD mpeg2 video format & an AC3 video format, wrapped in a mpeg-privateElementariesStreams (aka an almost identical wrapper as DVD-VIDEO)
MPSC and the mpeg2 codec (PS: you just buy a license, not a developpement cost for this price) will does it nicely (from memories: just convert to 1440*1080px, Apple Intermediate Codec)
bad idea: FCE does not handle HDV (or every MPEG2 files) for editing. This features is only for FCP.btw - I can use Mpeg Streamclip to demux to the m2v and accompanying audio file which easily imports into Final Cut Express but... I want to use iMovie 11 as it's easier to use for a novice like me...
So convert first to AIC, use an FCE's setting/template "1080i", import and edit
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
TOD file corrupted
By xavier039 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2009, 13:06 -
lost timestamp on tod files
By mpunt in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2009, 15:49 -
.tod to dvd
By dirtyfosit in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2008, 03:23 -
Conversion video loss? Which is better (TOD-->TS and TOD-->MPG)
By mvincent in forum Video ConversionReplies: 1Last Post: 21st Apr 2008, 09:01 -
TOD file conversion
By perc01 in forum Video ConversionReplies: 3Last Post: 14th Dec 2007, 06:18
