Hey all!
I'm trying to get a 10GB Bluray file onto my PS3, but I need to split the file into three parts to transfer it on a FAT32 storage device first. I don't have a cross-over cable so it's a last resort really. Does anyone know any software that can split it without losing the quality?
I tried a few free programs but I don't think they were prepared for a file that big.
Appreciate any answers! Thanks in advance,
Ryan
	Thanks for your reply! I have two blu-ray files, the first one was a .mkv (the original) and I converted to a .mpeg. Neither of them work with this program either, both turn up the same error message:
 Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\Documents and Settings\dicksmith electronic\My Documents\Downloads\Avatar (2009) 1080p BluRay\Avatar.bluray.x264.mpg
 I set it to split every 3GB, checked the button saying "Blu-Ray disc" and hit "Start Muxing." Repeated the process with both files and also tried to check TS Muxing to see if it made a difference, but that turned up the same error.
	THose are not any blu-ray files. Moving you to our video conversion section. Please try give all details and it will be easier to help...
 HOW did you convert to mpg?
 I would just try any mkv to mp4, vob, avchd/blu-ray converter https://www.videohelp.com/tools/sections/all-in-one-mkv-to-mp4-avchd-ts
	Had a look at your link. I should mention that I don't want to convert it again as I need a file format that the PS3 can read (MPG is the standard I believe) unless you know a better alternative? Can I still use this program to cut it?
 Thanks for your speedy responses by the way.
	Like I said, I'm a novice. Just spent 10 hours trying to figure out how to get this file on the PS3 without a cross-over cable and all it took was redirecting it to the D: Drive in the first place. Thanks a bunch for your help. I'm re-directing the new conversion there now and I'll (hopefully) make a final post to let you know how it goes.
  MKV to Blu-ray(ps3)By Looney in forum Blu-ray RippingReplies: 1Last Post: 2nd Feb 2011, 12:08
  how to split mkv file and subtitle file to play on blu ray via hdd usbBy julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28
  help: when a blu ray movies is split into more than one m2ts fileBy lodwales in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 10:51
  Blu-Ray Struggling Except On PS3By ejai in forum Newbie / General discussionsReplies: 76Last Post: 19th Aug 2008, 15:37
  blu ray on PS3By kirstyholtkamp in forum Blu-ray RippingReplies: 7Last Post: 2nd May 2008, 17:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
