i converted an mpeg video recorded with my tv tuner to an 60FPS avi using TMPGENC express, and it looks A LOT smoother.
however, when i play it on my mede8er or my DVD player, it's pretty choppy.
is there any way to convert my mpeg to 60 FPS video so it could be played anywhere and still retain smoothness?
original MPEG:
TMPGENC 60FPS avi:Code:General Complete name : C:\Video_1229-1725(CH-96).mpg Format : MPEG-PS File size : 177 MiB Duration : 3mn 49s Overall bit rate : 6 463 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format_Settings_GOP : M=3, N=15 Duration : 3mn 49s Bit rate mode : Variable Bit rate : 6 000 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.579 Stream size : 163 MiB (93%) Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 3mn 49s Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Video delay : 103ms Stream size : 6.12 MiB (3%)
Code:General Complete name : C:\Video_1229-1725(CH-96).avi Format : AVI Format/Info : Audio Video Interleave File size : 144 MiB Duration : 3mn 49s Overall bit rate : 5 271 Kbps Writing library : TMPGEnc 4.0 XPress Version. 4.7.4.299 Video ID : 0 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Muxing mode : Packed bitstream Codec ID : XVID Codec ID/Hint : XviD Duration : 3mn 49s Bit rate : 4 925 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5:4 Frame rate : 60.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.198 Stream size : 135 MiB (93%) Writing library : XviD 1.2.1 (UTC 2008-12-04) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 3mn 49s Bit rate mode : Constant Bit rate : 320 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Stream size : 8.75 MiB (6%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (1.44 video frame) Interleave, preload duration : 432 ms
Results 1 to 11 of 11
Why convert it at all? It plays smoothly kept as an MPEG or perhaps authored for DVD.
It's not smooth since you converted a 25fps interlaced source to 60fps. Now, if you had converted it to 50 fps then that might play smoothly. If you advance frame-by-frame, you should see that one frame in every 6 is a duplicate, hence not smooth playing. Why would a European want a 60fps video?is there any way to convert my mpeg to 60 FPS video so it could be played anywhere and still retain smoothness?
A sample from the source MPEG might prove useful to confirm that the source is really interlaced and that it's not converted from NTSC. -
Nope. Convert it to standard framerates like 25fps if you want it to work correctly on dvd players.
i see what i see, and i see that the other video is much smoother.
And also perhaps a small sample of the one you claim is smooth playing (except when played on your DVD player or a Mede8or (whatever that is)). A short 10 second sample of both, ones showing steady movement, would be good. It's hard for us to guess what you have.
Also keep in mind that 50 fps or 60 fps can be quite strenuous on a player. So even if you did the conversion perfectly the player might have problems with it. Looking at the specs for the Mede8er it looks like it should be able to play 50 or 60 fps. Try the Xvid AVI in this clip:
https://forum.videohelp.com/threads/307004-Best-framerate-conversion-%28eg-23-97-to-30-...=1#post1888926 -
http://hotfile.com/dl/93959176/b959469/example.rar.html
here, i've cut a little part of the original video, then converted it to 60fps avi with tmpgenc, and uploaded both in this archive.
so see it yourself and tell me is there any difference. -
As manono suggested earlier, the 60 fps file has one duplicate frame in every group of 6 (ie, one frame is duplicated to turn 5 frames into 6, 50 frames into 60). On a 60 Hz display that will show 10 tiny jerks every second. On a 50 Hz display it will usually play a little more jerky because you can't specify that only the duplicate frames be discarded. But both will be hard to see unless you have a long, smooth, medium speed panning shot. If you're watching on a 50 Hz display you'll be better off converting to 50 fps.
Both the original 25 fps interlaced MPG file and a 50Hz Xvid should play equally smoothly. If not, something is wrong with your playback.
50 fps Xvid AVI attached.Last edited by jagabo; 3rd Jan 2011 at 13:39.
thanks a lot.
your 50fps avi is less jerky on my mede8er than both 60fps and 50fps avis i created with tmpgenc, so virtualdub seems better for this job.
it's not perfect as it is on my pc, but it's better indeed. now i'll have to experiment a little (any tips will be appreciated, since i always, for some reason, avoided using virtualdub). -
Very possible. My suggestion is to lower the resolution, perhaps by doing a proper resize. For me the AVI plays at the wrong aspect ratio. Perhaps resize it to 640x480 and try again since, at 720x576, you're probably at the limit of what your player can handle (haven't seen the specs), the increased framerate stresses it even more, and at a lower resolution it might play more smoothly. And don't convert it to 60fps. If you insist on bobbing it, (why?) use 50fps.
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 06:37 -
FPS question
By pfxz in forum Newbie / General discussionsReplies: 3Last Post: 11th Jul 2008, 13:58 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
dvd fps question
By Shaorin in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Nov 2007, 10:06 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 08:35
