I am seeking advice on an archiving project.
I have a number (30 1 hour tapes) of Mini DV tapes dating back 7 or 8 years. I would like to archive on portable harddrives to preserve.
I am trying to meet the following needs
1-Would like to store with no loss of quality or minimal loss if there is a good compression option that does not limit future options in using the files. (Disc space not an issue given price of external hard drives)
2-Would like to be able to watch directly from harddrive using devices like Apple TV or Western digital video player.
3-Would like to be able to burn DVD's from master files as needed - could compress as needed at that time.
4-Ideally use software and formats that are most likely to be around for a long time
5-Ability to copy entire drives full of data to allow sharing copies with family members and back up as needed.
6-Keep it as simple as possible. While I might do some editing in the future I just want to get all the raw data stored at this time. At this time just want to label each tape with dates.
7-Prefer to work with PC system although Apple hardware available.
Next phase of project will involve doing the same for about 50 8mm video tapes (analogue) but I will tackle the digital tapes first
Chuck
MiniDV to your computer via Firewire connection....no quality loss since it is a "data transfer". They will be big files though.
Ok
What software would you recommend for the transfer and organization of these files?
I am using a pc with windows 7
Thanks for your help
Chuck
Ripping home video DVD's for archiving purposes suggestions?
By Parafly in forum DVD RippingReplies: 1Last Post: 10th Jan 2012, 15:53 -
Archiving Digital-8 Home Movies... or The Winter of My Discontent
By receptacle in forum Video ConversionReplies: 5Last Post: 19th Mar 2009, 14:00 -
Archiving old hi-8 video?
By tchambers in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 10th Aug 2007, 15:32 -
Archiving Home Video on a computer
By chuckaug in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2007, 15:38 -
Archiving Video
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jun 2007, 22:15
