Closed Thread
  1. AdrenalineWomenGunsCars mrjust's Avatar
    Sep 2008
    I was trying to play one of my shows but It wont play
ID:	4951Also this is mediainfo
    General
    Complete name                    : C:\Users\Administrator\AppData\Roaming\uTorrent\naruto shippuden Season 1\Naruto Shippuden 32.avi
    Format                           : MPEG-4
    Format profile                   : Base Media
    Codec ID                         : isom
    File size                        : 176 MiB
    Duration                         : 23mn 39s
    Overall bit rate                 : 1 038 Kbps
    Encoded date                     : UTC 2010-03-22 07:49:12
    Tagged date                      : UTC 2010-03-22 07:49:12
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L3.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 8 frames
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 23mn 39s
    Bit rate mode                    : Variable
    Bit rate                         : 906 Kbps
    Maximum bit rate                 : 5 742 Kbps
    Width                            : 640 pixels
    Height                           : 480 pixels
    Display aspect ratio             : 4:3
    Frame rate mode                  : Constant
    Frame rate                       : 23.976 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.123
    Stream size                      : 153 MiB (87%)
    Writing library                  : x264 core 80 r1376M 3feaec2
    Encoding settings                : cabac=1 / ref=8 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=0.6:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=16 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=906 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.00
    Encoded date                     : UTC 2010-03-22 07:24:42
    Tagged date                      : UTC 2010-03-22 07:49:15
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format version                   : Version 4
    Format profile                   : LC
    Format settings, SBR             : No
    Codec ID                         : 40
    Duration                         : 23mn 39s
    Bit rate                         : 128 Kbps
    Maximum bit rate                 : 140 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : Front: L R
    Sampling rate                    : 44.1 KHz
    Stream size                      : 21.7 MiB (12%)
    Language                         : English
    Encoded date                     : UTC 2010-03-22 07:49:14
    how do I play this video?
    Just buy it on dvd/blu-ray. Problem solved.
