I converted the ts into mkv using handbrake, i only changed the resolution to 1360x768 which my monitor supports, kept bit rate unchanged and constant ratio "0" but still some player cannot play only splash player pro can play.
what should be the best converter? ripbot or handbrake or something else?
best format?
best resolution ? 1360x768 which is the specification of my monitor or 1920x1080 the original ts specification
	Are you converting to h264/avc? They are all based on x264 so you should get similar quality if you use same settings. And use standard resolutions like 1280x720 or 1920x1080.
  Is there a converter that can match the input and output bitrates?By aslaksen in forum Video ConversionReplies: 6Last Post: 22nd Feb 2011, 04:53
  Fast Video Converter - quality of output?By tonyp2 in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 16:08
  Blu-ray player in computer versus standalone in terms of qualityBy canadianjameson in forum DVD & Blu-ray PlayersReplies: 10Last Post: 29th Jun 2009, 16:53
  HFS10, want live output to SVHS input. Need converterBy tepeco in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 3rd Jun 2009, 11:51
  "Any Video Converter" output format choices - can anyone explain?By slipkid in forum Video ConversionReplies: 5Last Post: 14th Feb 2009, 18:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
