Someone gave a tip to improove my capture quality, but I do not know how to capture in mpeg2.
I am usin Vdub. Do I need a codec to do that???
Thanxs
To be honest I dont know if you can capture real-time MPEG-2 with Virtual Dub. Even if you could, I would suggest capturing in .avi format, then convert to MPEG-2 with TMPEGENC or another encoder. Reason being is you will need a very fast computer to capture real-time MPEG-2, and even if you would try it, the quality will suck. Capture .avi, then convert afterwords--better quality.
MPEG2 with LPCM -> ? (less MB demanding format)
By Zetti in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 13:12 -
Conversion of DVR-MS to Standard Mpeg2 Format
By jaffacaique in forum Video Streaming DownloadingReplies: 2Last Post: 13th Apr 2009, 04:40 -
Best format for MiniDV convertion (Mpeg2 or H264)
By bisli29 in forum Video ConversionReplies: 6Last Post: 3rd Dec 2008, 03:49 -
Position of subtitle & mpeg2 format
By akakiami in forum SubtitleReplies: 9Last Post: 26th Nov 2008, 01:22 -
Capturing - to what format, DV or MPEG2.?
By Airjrdn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 28th May 2008, 06:45
