Hello;
How can I write a Blu-ray disc with its menu on a DVD9 DL media?
Be aware BD Rebuilder doesn't decrypt or rip the movie to the hard drive. You'll need AnyDVD HD or DVDFab for that if you are working with a commercially made blu ray movie.
You can convert a Blu-ray to a Video DVD with BD Rebuilder, but you cannot preserve menus. AFAIK there is no such software. But you can make a BD9 (Blu-ray structure on a DVD DL media) or BD5.
I want to make DVDs with menus into the vob into the MPEG-2, but I have friends who do not know how this necessary
u can use Multiavchd. It will take Blu Ray files and convert them down to mpeg2/Vob's...u can't preserve the blu ray menu though.
Hi friends,
One of the friends has become successful to have a DVD from bluray as VOB WITH ITS COMPLETE MENU. The example picture of the menu is below. The film is Terminator Salvation (2009)
I didn't figure out how he made it. He isn't online so I cannot ask.
Is there anyone who have a good idea with this?
Videocalc
ProCoder 3
dgdecnv
TSMuxer
TranzcodeGUI
SurCode DVD-DTS
Sony Vegas 7
BDSup2Sub
MuxMan
DvdReMakePro
DVD Architect Pro
These are menu codecs
General
Complete name : D:\DVD KAYITLAR\Terminator_IV_2-DVD9\DISC_1\VIDEO_TS\VTS_01_0.VOB
Format : MPEG-PS
File size : 165 MiB
Duration : 55s 264ms
Overall bit rate : 25.0 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 55s 188ms
Bit rate mode : Variable
Bit rate : 24.0 Mbps
Nominal bit rate : 9 500 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 2.320
Stream size : 158 MiB (96%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -67ms
Stream size : 2.95 MiB (2%)
Text #1
Format : RLE
Format/Info : Run-length encoding
Video delay : -67ms
Text #2
Format : RLE
Video delay : -67msLast edited by cavusozkan; 7th Jan 2011 at 13:41.
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
convert non blu ray movie to blu ray disc???
By dalmar6677 in forum Authoring (Blu-ray)Replies: 2Last Post: 31st Aug 2010, 18:51 -
How do I burn a 1:1 copy of a Blu-Ray rip DVD5 or DVD9? AND...
By hakoreh in forum Blu-ray RippingReplies: 8Last Post: 13th Mar 2010, 17:31 -
Blu-ray backup to DVD9???
By blusky1 in forum Blu-ray RippingReplies: 25Last Post: 2nd Jan 2010, 22:40 -
Blu-Ray Rip to DVD9
By DeathStalker77 in forum Authoring (DVD)Replies: 2Last Post: 23rd Sep 2009, 18:03
