I'm putting together a highlight video for a football player. I know all about capturing from a VOB file, etc. In any event, the DVDs his coach gave me are not importing. My Pinnacle Studio 14 Ultimate Version, is not recognizing the disk. It seems there is a lock on the DVD. Ultimately, after I tried importing it a few times it said that the IFO files were either in use, or locked. I downloaded an IFO Decrypter, created files, but it's still not working. Is there anything I can do? His coach is on vacation and I have a deadline. I would appreciate help on this matter. Thank you for your time.![]()
Closed Thread
Try using the free DVDFab HD Decrypter to decrypt the DVD to your hard drive and then try to work with the decrypted files in Pinnacle. You can't really "lock" DVDs but perhaps whoever made this DVD was anal about it being copied without payment and they may have put some bad sectors, etc. on it to try to thwart that. DVDFab should be able to get you a sane copy to your hard drive that you can work with.
Note that weekends in general are periods of low participation for many forum regulars and unfortunately for you this is also a holiday weekend which may make it harder for you to get help.
vobblanker error "ifo has more than one pgc, not supported"
By patz in forum Authoring (DVD)Replies: 15Last Post: 26th Apr 2012, 02:58 -
"Hide" field locked in Subtitle Workshop
By neuroxik in forum SubtitleReplies: 0Last Post: 17th Aug 2011, 03:08 -
Need help: Trouble importing/capturing a "locked IFO" on DVD
By mattday79 in forum Capturing and VCRReplies: 3Last Post: 1st Jan 2011, 14:41 -
SubtitleCreator - "Could not get interfaces" when opening IFO
By ecc in forum SubtitleReplies: 1Last Post: 19th Jun 2009, 22:43 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
