I've got a Divx file, apparently the audiostream is AC3 encoded.
Virtualdub reports the following for the audiostream:
Sampling Rate: 48000Hz
Channels: 5 (stereo)
Sample precision: 0-bit
Compression: Unknown (tag 2000)
Preload Skew: 24000 samples (0.50s)
I had difficulty hearing any audio until I installed WinDVD 3, now I can hear the audio OK.
The problem is I want to convert this file to SVCD to play in my DVD player.
I usually just grab the audiostream using virtualdub and then encode using TMPGenc.
Ideally I want to keep the surround audio, however at the moemnt I can't even convert to normal stereo. I've tried converting using virtualdub, but it just complains - stating "The requested audio compression is not compatible with the input format".
TMPGenc just ignores the DivX's audiostream and encodes just the video.
Anyone got any ideas?
:o :o :(
Results 1 to 1 of 1
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47 -
Properly encoding multi-channel AC-3 to multi-channel AAC
By PuzZLeR in forum AudioReplies: 1Last Post: 15th Nov 2007, 13:07
