Hi m8
happy new year,my blueray home cinema HT_BD 1250 remote dont work with my system it new and in the manuel the remote can be programmed to pick a tv, I cant tell whether i have touch some on the remote please help![]()
Results 1 to 13 of 13
harmony
what is 42? thanks 4 response
here with a correction,in the manuel the remotes model is AH59-021445 and the remote attach to my system is AK59-00104jLast edited by saayacoolu; 1st Jan 2011 at 12:34.
harmony -
Page 18/19 of the manual (HT-BD1250_XAA.pdf), "Remote Control", has instruction how to set and use the HT remote with a tv of another brand.
thanks,in my case the remote attach to the system is not working.I pressed every key on the remote no response.
harmony -
The Samsung AH59-00104J remote was produced for the Samsung DVD-SH893, DVD-SH895 or DVD-SH897. You got the wrong item.
The AH59-021445 doesn't exist; that last glyph is the letter "S". I've seen 'em sold on Ebay, although the Samsung site's search function doesn't have anything on that part number. -
thanks so much 4 concern i will look 4 the right remote,once u have given the part number
harmony -
I had the right remote for my samsung HT-BT1250 and i tried the code enter 84269 enter to make the dvd region free but all in vain the deck refuses to play video cd,can some please help
harmony -
am still looking 4 the region free code for this player.help some where.
SAMSUNG HT-BD1250harmony -
Most Samsung players CANNOT be made region free. I've NEVER heard of any home theater model bluray player that can be made region free.
Thanks for reply but i had this from a forum of which i tried and not working the way i like it
I follow the instructions posted by fmcardoso and works for my HT-BD1250. Below are the instructions:
I found it`s possible to install a firmware from another country.
With this, it's possible to see DVDs ou BDs from another region, AND take advantges from other features published only on another country firmware, for example: in Brazil don't have Netflix and Pandora networks, so Samsung let them see AVI/DiVX files from USB or DVDs.
To install a firmware from another country:
- download/unzip the firmware
- using a Hex Editor edit the RUF file
- locate the 3 letters code that identify the country of this firmware, it's like XAA (for US)
- change to the your-model's country (see at BD-P1600 system information)
- Follow the rest of normal procedure
Good movies!!
[IMG]file:///D:/All%20Satellite%20Prog/DVD%20%20SOLUTIONS/dvdhacks%20ht-bt1250_files/icon_minipost.gif[/IMG]Region code hack posted by yawara, November 14 2010:
Hi,
I used this hack for my Samsung HT-BD1250
(This hack is allso supposed to work with HT-BD1220,
HT-BD1250, HT-BD1252, HT-BD1255, HT-BD2ET, HT-BD2T,
HT-BD3252, HT-BD7200, HT-BD8200, HT-DB120, HT-DB1650, HT-DB300, HT-DB600, HT-BD650, HT-DB750M, HT-DB760, HT-DB770)
1. Open the disc tray and remove any discs
2. Close the disc tray
3. Switch Off Player and Unplug from mains wait minimum 30 seconds - this resets the memory, and RAM of the DVD/BlueRay
4. Make sure your TV is on as usual, and Reconnect to mains
5. Turn on your DVD/Blueray player with remote and wait for the "no disc" message to appear
6. PS! As quickly as possible, using your controller press - ENTER 8 4 2 6 9 ENTER
7. You have been successful when a blue box appears in the top left-hand side of the TV Screen, displaying the message "DVD Region Free"
I had to attempt the "ENTER 8 4 2 6 9 ENTER" sequence several times before i got the Region Free message - so keep trying, and Good luck!
harmony -
does anyone have an updated unlocking code. I just received a BD1252 with firmware 2.8 and can't get the code to work no matter how I try it. My swedish sis-in-law who gave me the player had no need to unlock it, but I'm an American living in Swedish, so I have hundreds of region 1 DVDs I want to play on it but can't.
DragonsDream - You can always ask, but in the future we'd prefer you just make a new post. You're arguably hijacking this thread, which we don't like, but it's also arguable given the subject that you are on topic. Anyway...
If you want a region free player then you need to avoid Samsung and Sony. It could be that firmware and/or hardware changes made during production (and this happens a lot more than you might think) have rendered the unlock codes useless for your particular model. saayacoolu talked about using another country's firmware and I cannot recommend this as some have bricked their players doing that. If you just want a region free DVD player, despite their official denials Philips still makes a large number of DVD players that can easily be made region free. Personally I have a cheap Philips DVD player that's region free and I use it for DVD watching to take some of the wear and tear off my Momitsu region free BluRay player. You could just spend around $50-60 US and get a cheap Philips player you can make region free or maybe a Pioneer. But avoid Sony and Samsung.
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 11:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 10:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 17:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 23:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 02:42
