Hi.., I got a minor confusion in the latest version of handbrake, if i want to convert a DVD movie to x264.mkv i choose high profile in preset & in output settings it shows: OUTPUT SETTINGSPreset High Profile), but after i load the movie and configure all settings, the output settings shows : OUTPUT SETTINGS
Preset Custom). My question is that why i get preset as custom in output settings even if i select high profile ?.. is that a problem or is custom & high profile are same..? please advice me if you got any knowledge regarding this subject.. Thanks in advance...
skorpinok
	Try selecting the preset after loading the video.
 Still, I often need to correct settings after loading a preset.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	High Profile in Handbrake is simply a predetermined preset. If you change anything...it switches to custom.
 For instance, said setting defaults to a mp4 container. If you switch the container format to mkv, you're already changing an aspect of the preset, thus, output changes to custom.What exactly is rotten in Denmark?
  Aspect ratio confusion (handbrake)By litmus in forum Video ConversionReplies: 4Last Post: 16th Jan 2011, 13:27
  confusion with mactheripper, perian & handbrakeBy yoly in forum MacReplies: 4Last Post: 7th Feb 2010, 03:48
  Does anyone have a MASTERING Preset for tmpgenc plus?By underp in forum Video ConversionReplies: 0Last Post: 31st Mar 2009, 12:26
  File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPodBy GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56
  PS3 Preset Anyone?By croops in forum ffmpegX general discussionReplies: 1Last Post: 27th Aug 2007, 20:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
