Hi,
I'm trying to use BD-RB (ver 0.36.09) to shrink a BD-50 to BD-25 (original size 32GB) with full backup (remove other languages). However, the output size is larger than set in the program (set to 23450MB, actual 24943MB, larger than BD-25 [23866]).
The disk being copied is Christmas Carol (2010).
I have previously copied several BD-50s successfully, I just can't get this one to work.
Running Inspect, I get the following:
- Windows Version: 6.1 [7600]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Isn't recommended version
- FFDSHOW: 3154, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- BD Rebuilder v0.36.0.9, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
ffdshow is latest build (tried updating when I first had the problem to latest), Haali splitter shouldn't have any effect on file size detection?.
The two log files for the output show the following:
BD-Rebuilder:
- Input BD size: 32.76 GB
- Approximate total content: [02:23:02.823]
- Target BD size: 22.90 GB
Disk INI:
SOURCE_SIZE=35180285885
SOURCE_VIDEO_SIZE=34608986112
TARGET_SIZE=24589107200
REDUCTION=.693976048569429
I'm currently doing another blu-ray, so I'll see if the error was to do with the disk (maybe summing audio sizes wrong?)
Any ideas as to how I could get the disk to be smaller?
Your versions of ffdshow and Haali are not those recommended (i.e. tested) by jdobbs. You may get away with it, but the bug report thread is full of problems traceable to the user refusing to use recommended versions. Some versions of ffdshow and Haali are more problematic than others. The tested versions are available here:
http://forum.doom9.org/showthread.php?t=143716
Okay, that's out of the way. Your problem is probably something besides the decoder/splitter you're using. Most likely it's just a peculiarity of that particular disc, and remember BDRB is still beta.
If it's only this one disc, you can set a custom output size of, say, 22000MB and probably be close enough.
And welcome to the forum.Last edited by fritzi93; 31st Dec 2010 at 20:45.
Pull! Bang! Darn! -
Tried another BD, which completed right on target (23450). Retried the one that wasn't working at 22000, also completed exactly on size. So there was something it didn't like about 23450 for that disc.
Oversize DVD's
By oldtimer33 in forum Authoring (DVD)Replies: 4Last Post: 15th Feb 2012, 07:29 -
VDubMod Oversize Files
By NeroLi8gerzid in forum Video ConversionReplies: 2Last Post: 6th Oct 2011, 05:16 -
Converting mkv to dvd always results in an oversize iso
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 23:16 -
StaxRip - oversize problem
By zacharias in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2010, 13:10 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 15:17
