I use ProjectX (java app.) to rip subtitles for a 256 or 4 color SUB stream rip. This makes a DVD idx/sub file. To make them work for the converted (mkv I assume) file I use BDSup2Sub512 (also java app.) . Just open the idx in the BDSup2Sub512 app. and only set free adjust (window opens after the file is opened) to .5 for x and y. Then hit OK. Then select from the menu EDIT, Move All Captions (if the subtitles are not already in the correct screen position) to what you find the best place on the screen. After this click the button "Move All" You can see the results in the split screen per subtitle. When satisfied use FILE menu to export. Add this idx (keep the SUB file until after muxing the subtitles into the mkv) in MKVmerge GUI together with audio and video and mux away.
Bluray/DVD Burned In Subtitles with no Video Compression?
By Tony Jenkins in forum Newbie / General discussionsReplies: 6Last Post: 29th Apr 2011, 18:24 -
DVD Subtitles to Bluray rip in mkv
By Flarup in forum SubtitleReplies: 1Last Post: 11th Nov 2010, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10 -
add DVD subtitles to a bluray disk
By berendho in forum SubtitleReplies: 1Last Post: 30th Aug 2008, 18:30
