I am trying to convert the chinese srt into a sub/sup file so I can mux them onto a HD movie file. I want the subtitles to look legitimate so I want the subtitles to be in HD. So far I can only find programs that can convert to chinese but very bad quality (subtitle creator) and convert to HD but are in gibberish (Clown_SRT2XMLSUB or SubConverter). Is there any way that this can be done without the headaches.
I can only tell you that doing subtitle work in character sets other than Latin is rather difficult. Most subtitle utilities don't support Unicode, so that means that you usually have to do something like this.
Under Regional and Language Options in the Control Panel on Windows you have to go to Advanced and under "Select a language to match the language of the non-Unicode programs you want to use" you have to pick the appropriate Chinese language option. Then you will likely have to reboot and poof! Your PC now speaks Chinese. But the downside is that all your menus and program names may now be in Chinese so you better be able to read it yourself. Assuming you can read Chinese then you can start a subtitle program and try to get it to use Chinese characters and it may be able to create the output you want. I am not responsible for any side effects that happen if you try this method including any problems that may or may not happen to other non-subtitle programs as a result of trying this.
If you cannot read Chinese then you should NOT try what I talked about.
If you get this to work at all it could still be very time consuming. -
Unicode has been around for 10 years, all major OSes support it now. If software publishers won't support it, they risk to be come obsolete. Especially when you deal with multi-language texts, like subtitle utilities. Those that don't support it, should get in the game, fast.
Thanks jman98, your advice helped. I don't actually can't read chinese and I took the risk and all the menus remained in english. All the subtitles are shown in chinese using Clown_SRT2XMLSUB.
How do I convert DVD or sub/idx to text srt subtitles?
By Baldrick in forum SubtitleReplies: 70Last Post: 28th Mar 2016, 21:37 -
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 12:04 -
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 05:23 -
Subtitles Tools (SUB to SRT 1.33) for OCR Chinese Txt to SRT
By dennis3377 in forum SubtitleReplies: 0Last Post: 10th Dec 2009, 01:46 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45
