Hi,
I'm a novice when it comes to video editing. I know what I want to do and I'm fairly certain I have the software to do it, but I'm just looking for some advice on how to go about it. Ok, so I have a video clip that I downloaded (roughly 2hrs in length). It's an MP4 with H.264 codec and it's dimension are 576x432. I'd like to burn the clip onto a DVD without losing much if any video quality. I have Adobe Premiere CS3 and Adobe Encore CS3. I was goin to try exporting from Premiere to Encore using one of Premiere's presets, but it said it was going to take nearly 24 hrs to render!!!
What's the best way to go about this, in a shorter amount of time, without losing much quality? What's the best codec to use? I also have VisualHub and MPEG Streamclip. Hopefully you understand my frustrated rambling. Basically I just want to take the clip I downloaded, resize it to 720x480 for DVD and reformat it to mpeg-2 or .mov. (something that Encore will accept).
Please somebody help! Thanks so much!
If it's 2 hours in length, then it's a movie, not a clip.
Do you want to edit it? Is that why you want to import it into Premiere? If you want it on DVD, the best codec to use would be MPEG-2. Consider tools like AVStoDVD or ConvertXtoDVD. -
Sorry, I'm not familiar with the terminology. Yes, I'd like to edit out some commercials and add in some fade in/out effects in Premiere. I have it all edited...just not sure about exporting. Thanks, any help is much appreciated! Also, I'm on a MAC..forgot to mention that.
Saving Vegas 9 Video-Clip in Older Format
By TKB in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2011, 04:07 -
Webcam video (.mov format) audio synch help needed
By chrisj in forum Newbie / General discussionsReplies: 0Last Post: 23rd Mar 2011, 17:55 -
Video Clips For Buttons - Format & Spec?
By EViS in forum Authoring (DVD)Replies: 5Last Post: 19th May 2008, 08:21 -
Software To Crop A Video & Encode It In .avi Format
By rahul.never2far in forum Video ConversionReplies: 2Last Post: 25th Sep 2007, 02:50 -
Enlarging and restoring video
By Crac59 in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 18:36
