I purchased a external HD to backup My Documents and other things. Can someone give me the steps or information on how to drag and drop my emails to my external HD ? I use Outlook.
Results 1 to 12 of 12
The free software ' MozBackup ' is simple and reliable so use it with the firefox browser and the thunderbird e-mailer . Dont know what your query is doing on this forum but there you are .
You didn't say which version of Outlook your using, but you can go into Outlook and "Export" to a .pst file and save that, you can specify folders, inbox, contacts etc.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
I'm not sure about Outlook, but with Outlook Express you can drag and drop the entire folder or individual DBX files:
C:\Documents and Settings\USERNAME\Local Settings\Application Data\Identities\{some_bigass_long_number}\Microsof t\Outlook Express -
Do a search for your "*.PST" file. Copy it. Done. If you have Archive files, and you want to back them up, they will be in the same place.
Then bring up the page with your Account settings. Print that. Write down your password. Check the additional settings page. Print that. -
These may be useful:
http://www.sevenforums.com/browsers-mail/10497-importing-mail-outlook-windows-live-mail.htmlImport Outlook PST into Windows Mail:
http://blogs.technet.com/b/james/archive/2007/06/25/import-outlook-pst-into-windows-mail.aspx
http://windows.microsoft.com/en-US/windows-vista/Import-messages-into-Windows-Mail-fro...utlook-ExpressImport messages into Windows Mail from Outlook Express: -
If I import my contacts/email in Microsoft Mail or Outlook Express how will this help me move them to my external HD and just having a bit of a hard time getting to moved.
Jagabo, the link that sent me to Windows seven forum... does that mean OS Windows 7 and if so does that mean that they have a XP Forum that I can join ? Please keep in mind it is early 8:30 am New Years morning. lol! I haven't got a full cup of coffee in me yet.Last edited by tcory; 1st Jan 2011 at 08:33.
The last link tells you exactly where the email and address book are (in Outlook Express) and how to enable "show hidden files and folders" so you can easily get to them with Windows Explorer. Once there you can drag/drop, zip, or whatever. I thought the others might give you some hints about where they are or how to export them from Outlook.
Export the PST. I do this weekly.
Is yahoo email down? - back up for now
By yoda313 in forum Off topicReplies: 5Last Post: 28th Feb 2011, 10:08 -
RE : email video
By chief-1 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2010, 00:19 -
Do you archive your email?
By ahhaa in forum ComputerReplies: 12Last Post: 19th Jan 2008, 11:27 -
change of email addy please
By nmadman2 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 12th Jan 2008, 08:15 -
Email Problem
By SIRCOOKS in forum ComputerReplies: 2Last Post: 2nd Jul 2007, 04:42
