There are some discs that it attempts to format and then it says, "This disc can neither be played nor recorded." That doesn't actually bother me too much. However, when I get a program properly recorded and I want to finalize the thing takes forever and is stuck on finalize. When I pull the disc out I end up extracting the data to an ISO with ISObuster, which works fine. But I'm thinking this DVD Recorder is way too temperamental. I wish there was a way for it to finalize properly.
Results 1 to 26 of 26
Are you using good blanks?
Compare what you have against this list: http://www.digitalFAQ.com/reviews/dvd-media.htm
Odds are that you're just using junky media.Want my help? Ask here! (not via PM!)
Okay, I will give it a shot. Do you know if the Verbatim ones from Office Depot are any good?
That would depend on which one's they are,
https://forum.videohelp.com/threads/319565-Verbatim-Life-Series-DataLifePlus?p=1983041&...=1#post1983041
This is where i usually get them,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817507003
http://www.newegg.com/Product/Product.aspx?Item=N82E16817507005
Last week i picked up two packs of +R's & they were $16.99 with free shipping.
They go on sale there all the time but even at $24.99 W/free shipping is probably going to be cheaper than office depot
They have them on sale at offcemax also for between $20-$25 but they have been carrying the crappy one's which is why i just order them from newegg.Last edited by Noahtuck; 30th Dec 2010 at 14:01.
Unlikely.
Read this: Which MCC brand Verbatim DVDs when I go to a retail store?
Best to buy online from Amazon. Cheaper, too. ($20 per 100-pack)Want my help? Ask here! (not via PM!)
I agree about the media, you're using about the worst media available, try changing that first.
If you still have problems you might want to consider trying to clean the spindle on your DVDR. Not sure how easy it would be on a Sony but what you describe sounds like your discs could be slipping during burning. If your DVDs have fine circular scratches on the innermost part of your DVDs(it should be crystal clear like glass) your DVDs are slipping. DVD cleaning discs do nothing to clean the spindle. -
Nah, I think it's the Sony product. The fact that you have to feed it a higher quality disc proves it. Probably a weak/cheap laser.
But I guess the case is all blingy and slick though. That's what you're paying for.
Memorex is no good? What about their slogan "Is it live, or is it Memorex"?Last edited by budwzr; 30th Dec 2010 at 16:52.
It actually did the same thing with the Verbatim disc. I recorded with no problems and then the thing wouldn't finalize properly. The finalize flashing light went on and the thing never stopped. It's almost like the thing jammed. It would stop or turn off. I had to unplug it. Then, when I tried to play the disc it said, "This disc can neither be played nor recorded." I usually end up having to use ISO buster to get the data off these unplayable semi-finalized discs.
I'm surprised you haven't yet mentioned (and no one's asked) what model Sony recorder you have? While its true memowrecks is lousy media, the alerts you've reported are known to pop up repeatedly when older Sony recorders are about to become doorstops. There is no repairing them, Sony no longer stocks parts, if this recorder is more than four years old you may just have to scrap it.
Regarding media, Verbatim is no guarantee of anything if your machine is tanking. The version sold in stores is all 16x speed, which newer DVD recorders merely tolerate and many older recorders gag on. If you have a very recent recorder, 16x Verbatim AZO is fine, and it works great on PCs, but older recorders can choke on it as easily as Memorex. Once your machine starts acting up, you need to shift over to the slower 8x media most recorders were (stupidly) designed around: 8x uses quite a bit less laser power and spins slower, so sometimes you can squeeze a few months more life from a dying recorder with it. The two most reliable 8x media types are Verbatim DataLifePlus DVD-R and TY/JVC Premium Silver Lacquer DVD-R, available from online media dealers and eBay. Avoid using +R media in older machines unless they're Philips or Magnavox brand, the first run of Sony recorders that claimed to be compatible with both -R and +R actually prefer -R and as they age this becomes more of an issue. -
Did you try cleaning the spindle, like I mentioned in post #10?
Your symptom is exactly what happens on Panasonic DVDRs when the spindle is dirty allowing the disc to slip during times when the disc needs to change speed quickly(editing disc, finalizing, etc.).
If you can't open the drive you may be able to somewhat clean the spindle by ejecting the tray, unplugging the DVDR and finally using a long handled Q-tip soaked in iso alcohol and a flashlight you should be able to clean the bottom spindle. It would be worth a try. -
The machine is dying: you've been astonishingly fortunate that it lasted this long. Sonys of that period could make remarkable recordings, but they have an unfortunate reputation of barely surviving their initial warranty period. Sony did not get its act together until the RDR-HX525 series, as far as durability and compatibility with a variety of disc brands. The RDR-HX500 was designed exclusively around the Sony-brand media of the time, which was actually JVC/TY OEM. Any other media tends to be rejected as "dirty" or hangs the machine at the finalization stage.
So I'm not being cute when I say: it absolutely blows my mind that you've been routinely feeding this "diiva from hell" Memorex and other typical discount media, and it has actually tolerated it for seven years: the unit deserves placement in the Sony hall of fame or something. This is unheard of with that series of recorders. Throw some salt over your shoulder and thank the recorder gods for letting you get away with this for all that time, but your run of luck is over now- once these Sonys start failing finalization, they are doorstops. jjeff means well with his cleaning advice but it doesn't revive this series of Sony: the burner is simply on its last legs. You can try to keep it limping along by switching to TY/JVC media, if you insist your RDR-HX500 prefers +R (very unusual) TY/JVC does also make +R. A spindle of 100 costs about $37 shipped from places like supermediastore.com. If this media doesn't work, the recorder is dead: pull the plug and bury it, the discs will work perfectly in any other recorder and are the best you can buy.
Unless you enjoy going the ISObuster route to finalize every single DVD the machine burns until it finally dies completely, you need another recorder. There aren't any new DVD/HDD models available aside from the Magnavoxes at Wal*Mart and a couple of grey market import Panasonics from import dealers. Every now and then J&R Electronics offers a great deal on new-open-box Magnavox 513 models for $169 including free shipping. These have updated ATSC/QAM tuners, great recording quality at XP/SP, 320GB HDD, HDMI upscaling and a much more reliable burner than the RDR-HX500. Try one, you might like it, if not return it for refund and look for the much more expensive Panasonic EH69.Last edited by orsetto; 15th Jun 2011 at 12:38.
If you can easily remove the cover of your DVD drive, that's how it is done on a Panasonic. Otherwise some brands(I've been told Pioneer) aren't able to be easily taken apart. In this case you need a long handled Q-tip(long wooden handled Q-tips are used in the medial field or sometimes used to be used for VCR tape path cleaning) and get as good as you can from the front slot when the tray is extended.
Citibear may very well be right that your problem is a worn DVD drive vs. a cleaning problem but a cleaning wouldn't hurt either. During things like editing or finalizing a DVD needs to be able to change speed very quickly, if the disc slips during this process it can ruin a disc or make it unfinalizable. I have several unfinalizable DVDs made by my Panasonics before I learned how to clean the spindle, now I never really have such problems. -
I cleaned the thing, but it is still giving me trouble on the finalizing. I'm thinking I should try a Sony R+ Disc.
Good news! Hopefully you'll be able to keep things going for a while longer.
I'll suggest that now is the time to look at the Magnavox DVD recorders anyway.
Right now they are available, they have a digital tuner that tunes OTA and the clear QAM channels from cable and have a hard drive. I understand that a replacement DVD drive is reasonable priced and that the hard drive is easily replaced too.
I use one sometimes as overflow from my HD DVR. I'll be using it this fall when the networks start putting all the new shows on. This way I can record two on my HD DVR and one on the Magnavox. I setup the forward skip to 30 seconds and the reverse skip to 15 seconds to make it easy to skip over commercials. Makes a cheap Poor mans Tivo since all timers must be manual, however the 500Gb in mine holds a lot of shows. And since I keep basic cable I use it to tune the subchannels off of the HD network channels so I can watch Antenna TV for the old TV shows they show.
Record from a HD channel and the DVD quality is very good.If I'd known I was going to live this long, I'd have taken better care of myself. -
Good call jjeff and TimA-C!!
I am just a worthless liar,
I am just an imbecil -
There's no logical reason why that would help.
A similar discussion was recently had there: Issue with newly purchased Sony DVD+R
Based on available info, it's pretty conclusive that the machine is now in need of repair.
The DVD drive has likely gone bad.Want my help? Ask here! (not via PM!)
Sony dvd recorder model RDR-GX300 cannot play/record discs
By hdubya in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 03:40 -
My Sony CD/DVD player (NS55P) would almost only play sony discs.
By valdes001 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2011, 11:03 -
DVD burning, syncing Sony VDR-VC20 recorder with Sony Fx2100 camera
By NOSAINTS1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Sep 2010, 16:42 -
M2TS --> FLV via Haali and CoreAVC messes up Sony PMB
By CineManno in forum Video ConversionReplies: 1Last Post: 18th May 2009, 14:09 -
Formatting DVD+/-RW discs on Recorder
By mukeshs in forum MediaReplies: 2Last Post: 28th Dec 2008, 12:05
