Hi,
I wounder if it is nessisary to have aspi driver when I dont have any scsi devices ?
What does the aspi driver do ?
Do I get better speed in Smartripper ?
THX
/Stisse....
atapi devices ARE scsi devices; only the interface is ide. scsi devices will also work connected to your printer port would you believe
stan webber, thank you so much
is there neything special to do?
my friend wants to send me a pic of her, but her scanner is scsi and she doesn't have a scsi port. -
buy a scsi addon card. the parallel adapter will cost more, be harder to set up & severely restrict your bandwidth
ASPI drivers are used for digital audio extraction, cd ripping, and cd burning. Win98/Me ship with them, but for some reason they're not included with NT/2000/XP.
Many programs require you install some kind of ASPI layer before you use them (e.g. CDRwin, SmartRipper), and others use their own layer which is why you may be able to burn CDs with some programs in Win2K without having an ASPI layer installed.
If you're using an Adaptec product, you can download a file from their site (look for ASPI32.DLL) that will install the ASPI layer, which will work with all the programs that require ASPI.
On the other hand, if you're like me and think Easy CD Creator sucks, search for a program called Force ASPI, a hack of the Adaptec drivers that allows you to install them without having a qualifying product on your system. -
Also, it may be worthwhile to install the ASPI layer on systems running 98/Me because the one that ships with the OS isn't very good.
Connecting SATA hard drive in IDE PC
By alegator in forum ComputerReplies: 17Last Post: 13th Apr 2010, 15:00 -
Using Laptop (IDE) Hard Drive in New Desktop?
By ron spencer in forum ComputerReplies: 3Last Post: 30th Jun 2009, 14:21 -
DVD Player With IDE Drive
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2008, 16:44 -
board not finding ide drive
By 123fish123 in forum ComputerReplies: 7Last Post: 13th Jun 2007, 17:19 -
IDE + Sata Drive ?
By StoneColdWhat in forum ComputerReplies: 4Last Post: 17th May 2007, 16:50
