To all experts in this forum!
Is there anyone who has a running system like this:
- - Windows 7 pro 64Bit
- - Adobe Premiere CS5 Production Premium
- - New Intensity Pro with driver 3.9.1
I can install the driver (Control Panel is activ), BUT it requires to update the firmware everytime I boot the system.
When I do this I get an error message and Premiere is kind of blocked (doesn't play clips) (if I cancel the updating, premiere has the same problem).
Only if I am uninstalling the driver again, premiere works fine.
I guess it has something to do with the updating process to 64Bit.
Sometime Windows has a shutdown problem (hangs) with this driver too !!
Besides: The complete installation is FRESH!
Is this a known problem?
Blackmagic Support advised to:
- set the User Account Control, UAC to: never notify! - DONE
But the problem remains!
I had an Intensity Card on my older system (Windows XP 32Bit, CS3) and it worked fine!!
Does someone have similar problems?? ... or an equal system running?
Can someone help?
Greetings Uli
I've just had the exact same experience. Intensity support desk blamed it on Dell. They said they don't support Dell computers because of all the problems they've been having with them. But it's obvious by reading all the posts here that their problems extend well beyond Dell. x58 chipset - no good, Win 7 64 bit - no good, and so on.
The Intensity Pro, for a great number of users, has to be considered dead in the water at this time. BM comes out with new and improved drivers every month but so far, no luck. I would recommend not buying one of these capture cards until they can resolve their issues.
BTW, this same card worked perfectly in an XP 32 bit PC for the past four years.
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 12:55 -
Windows 7 Ultimate 64 - Intensity Pro 3.5.1
By XAM in forum Capturing and VCRReplies: 19Last Post: 14th Apr 2012, 07:19 -
VOB2MPG PRO command line not processing in 64bit Windows 7
By BJTHEDJ in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 6th Dec 2010, 15:53 -
Black Magic Intensity Pro and Windows 7 - is it supported?
By kILLDR3n in forum Capturing and VCRReplies: 1Last Post: 1st Jan 2010, 01:12 -
Blackmagic Intensity Pro Firmware Problems...
By Jaxel in forum Capturing and VCRReplies: 7Last Post: 3rd Mar 2008, 20:38
