Hi all,
Long shot but you never know. Has anyone used a 7" Asus eeePC (about 3 yrs old and running Linux which I am not familiar with) as an external monitor for a Panasonic camcorder, specifically the HDC-SD700. I have connected both using the Pannies' USB cable but can't get a streaming picture on the PC's lcd screen. I tried to edit the built-in webcam properties but all to no avail.
If I can it will save me buying another monitor! (For use with a DoF adaptor.)
Thanks anyone in advance and hope all have a safe New Year!!!
Phil
The USB ports on camcorders are almost for playback only. Your likely chances of getting an external monitor function is thru the multi-AV port of this camcorder.
Try setting the camcorder output to be monitored on the multi-av port and try it on the AV input of your TV first. If it works, then you need to buy a USB video capture device, and add it to your netbook, and get your external monitor function. -
AVCHD camcorders don't stream live over USB. All you could do is add an SD USB analog capture device. One that works with Linux.
http://www.kiva.org/about -
Thanks so much guys. Especially for the quick responses. Now I won't be wasting any more time trying to do the impossible.
A new approach is called for. Ta. -
Try a portable DVD player, most have video/audio in and come in sizes from 3 to 10 inches, and there cheap.
Thanks for the suggestions. Whilst I love and have many 'gadgets' in the house, would you believe I have never treated the kids to a portable dvd player! So off to borrow one from a friend to see if something like this will fit the bill.
Thanks chaps!
The most suitable external microphone for an ASUS EEE 701
By Haopengyou in forum AudioReplies: 4Last Post: 29th Mar 2012, 06:57 -
Blu-Ray on new machine and Asus VW246H monitor - Whoops?
By EwanG in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Oct 2009, 04:59 -
asus 900a eeepc mpeg-2 1080p playback
By dannyboy48888 in forum TestReplies: 1Last Post: 31st Mar 2009, 08:33 -
Using TV as external monitor, keeps dis- and re-connecting
By aceizace in forum ComputerReplies: 5Last Post: 5th Feb 2009, 14:26 -
external monitor problem
By compusic in forum EditingReplies: 0Last Post: 3rd Jun 2007, 22:33
