I just bought a little Zotac to serve as MythTV frontend. I added mythvideo plugin and now all my movies are listed and playable within MythTV ... but most of them need aspect ratio to be corrected.
Is there any way to edit file header(s) to let player know if it is 4:3, 16:9 or 2.35:1?
Results 1 to 10 of 10
Well, I have to answer my question myself. MKV container header can be edited to let player know how picture has to be scaled, mkvtoolnix has a tool for it. Works with Mplayer and mythvideo, these are the two players I use.
Thanks for posting your solution.
For avis can you use MPEG4 Modifier to change display aspect ratio. -
That's interesting, it claims it is modifying video header, not container header. Too bad it requires Windows, my last Windows died back in 2003.MPEG4 Modifier modifies a MPEG-4 ASP video (XviD, DivX) ...
But then again, from authors webpage:
Maybe it is modifying container header after all. Hmmm, don't have any AVI files either.The video must be in an AVI container. -
AVI doesn't really support aspect ratios. Mpeg4Modifier modifies the Divx/Xvid internal aspect ratio flags. It can only parse an AVI container.
Well, actually it claims to work on MPEG-4 ASP video, not only Divx and Xvid. I wonder if it works on plain video, without container. Also, it seems there is source code available ...
Divx/Xvid are two implementations of MPEG 4 ASP. Mpeg4Modifier only works with AVI files.
Well, actually it claims to work on MPEG-4 ASP video, not only Divx and Xvid.Yes, but not the only ones. BTW, I have been using AVC so this utility really can't help me.Divx/Xvid are two implementations of MPEG 4 ASP.
Because I'm interested in everything, even in stuff I cannot use. Folks around me often ask me for advice, see, they think I'm a geek and know everything. They are mistaken indeed, nobody knows everything, but I often can answer their questions. Do you condemn inquisitiveness?
MP4Box is another interesting utility, thank you.
Changing aspect ratio without losing any picture quality
By m93 in forum Video ConversionReplies: 9Last Post: 5th Apr 2010, 09:42 -
PgcEdit not locking aspect ratio picture
By andre477 in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2008, 02:52 -
Extract part of picture while keeping right aspect ratio
By cd090580 in forum Video ConversionReplies: 12Last Post: 6th Oct 2008, 07:04 -
Aspect Ratio
By mistycat in forum Video ConversionReplies: 8Last Post: 8th Nov 2007, 03:43 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 14:27
