Closed Thread
  1. Hi!
    I've had alot of problem with Premiere and Encore. Menubuttons not working, Encore crashing, Premiere not wanting to export footage to Encore and so forth...
    When I finally got everything to work i burned my project as a movie on a DL+ DvD 8,5 GB disc.
    I let Encore fit the movie to the disc and this was around 3h, 15 min with 5 menus.
    The first couple of chapters where fine but when I switched to a chapter with more motion (a tennismatch) the picture became all blurry and flickery. I thought that this was caused by the lack of deinterlacing but Im starting to wonder if its really a bitrate-problem? Trying to squeeze in to much film on one single disc.
    From what I first thought, there shouldnt really be an issue with interlacing on a tv-screen/dvd-player and why would only some chapters on the film be affected?
    The original film is from a VHS-camcorder.
    What do you guys think? And what should I do to get the best results? =)
    //GL
    USA
    garylanders, Do not post the same topic on several forums.
    Please do not cross post, once is enough.
    Continue in: https://forum.videohelp.com/threads/330019-Interlace-or-Bitrate?p=2043979#post2043979
    Moderator redwudz
