I have about 50 Video 8 home movie tapes captured with my Sony camcorder.I have started transfer to my hard drive in avi format.Each tape is averaging about 20gb.
Can I convert them to a different format that will maintain the quality and use a little bit less space?
Length of each tape in hours:minutes ?
The only thing that could retain quality is a very high bitrate low-GOP MPEG-2.
That may save 50% space, maybe.Want my help? Ask here! (not via PM!)
DVavi converts nicely to dvd spec mpeg-2 at about 1/4 of the size. but once encoded to mpg it is not as easily edited or converted to other formats.
It's easier to leave it as the full dv avi - assuming thats what you're capping to (13gb/hr fyi). These days hard drive space is much more affordable. Terrabyte drives are at an all time low. I'd go that route rather than compressing to save space. That way you have your maximum quality always on hand and convert later.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks guys for the quick response.I think I will leave them as avi,yes harddrives are cheap.
Thanks. -
Canada, eh?
Drop one of these in an enclosure: http://ca.buy.com/PR/Product.aspx?sku=213410517
Or use it as an internal SATA drive.
Then you'll be good to go.
2TB for a pretty decent price.
Then leave DV as DV.Want my help? Ask here! (not via PM!)
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
New storage capacity
By GideonK in forum Latest Video NewsReplies: 30Last Post: 11th May 2009, 13:48 -
CD Storage
By Nitro89 in forum Off topicReplies: 5Last Post: 1st Aug 2008, 10:13 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 04:32 -
DVD Storage
By kshavo in forum MediaReplies: 1Last Post: 30th May 2007, 16:21
