Hello,
I have a Samsung camcorder that records directly to SDD cards in MP4 format.
A few days ago I was shooting a theater of my son and I put the camera to record herself and she automatically made separate files with about 1.81 GB each.
The problem is that two files were wrong and I cannot open, (one with a 1.57 GB size and the other with 249MB), which is about 20 minutes of recording.
In each file, the camera recorded the same three files with extensions, and as example is one of them, are this three files:
HDV_0753.MP4
HDV_0753.idx
tmeD7kGJ
When I opened the file HDV_0753.MP4 on Windows Media Player the following message appears:
"Windows Media Player cannot play the file. It is possible that Media Player does not support this file type or requiring a codec that is not installed on your computer. "
In VLC Player appears:
"VLC cannot recognize the input format:
The format of 'G: \ 2VIDEO \ HDV_0753.idx' cannot be detected. Have a look at the log for details.”
When I check the MediaInfo of the file, only the following message appears:
"General
Complete name: G: \ 2VIDEO \ HDV_0753.MP4
File size: 1.57 GiB "
Unlike the other correct files, were I see a lot of information.
I've tried several programs to recover the file, including the "All Media Fixer" and I cannot open them, because many of the programs just fix AVI files and I cannot convert it, it gives error in the conversion.
It seems to me that the problem is in the index, which should be on file with the IDX and not inside the MP4, as it should be.
Someone help me?
What can I do to open these files and see the Christmas party of my son?
Thanks.
The solution to your problem is elusive to even the most experienced video experts. Those that have solved it did it by using a hex editor wherein the situation was caused by a corrupt header and by replacing the header with one from an uncorrupted video created by the same camera. Google "how to repair an mp4 file" and you'll see.
How do you convert HD 720p MKV file to MP4 HD file without losing quality?
By SoccerLover in forum Video ConversionReplies: 18Last Post: 4th Nov 2010, 08:30 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
VirtualDub "NewMovieFromFile" error w/mp4 file
By smk42 in forum EditingReplies: 3Last Post: 31st Dec 2009, 00:37 -
Any player that will play MXF file or MP4 wrapped file
By ljCharlie in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2008, 07:58 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
