Merry Christmas to Everyone here...
Here is DTS n AC3 Muti Audio Sample
The most of the players attenuated vocal dialogues.
Download Link-1
Alternate download Link-2
General
Complete name : DTSnAC3_MultiAudio_Sample.vob
Format : MPEG-PS
File size : 78.2 MiB
Duration : 1mn 10s
Overall bit rate : 9 291 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 1mn 10s
Bit rate mode : Variable
Bit rate : 6 752 Kbps
Nominal bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : 2:3 Pulldown
Bits/(Pixel*Frame) : 0.815
Stream size : 56.6 MiB (72%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1mn 10s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 3.77 MiB (5%)
Audio #2
Format : AC-3
Duration : 1mn 10s
Bit rate : 384 Kbps
Bit depth : 16 bits
Stream size : 3.23 MiB (4%)
Audio #3
Format : AC-3
Duration : 1mn 10s
Bit rate : 384 Kbps
Bit depth : 16 bits
Audio #4
Format : AC-3
Duration : 1mn 10s
Bit rate : 384 Kbps
Bit depth : 16 bits
Audio #5
Format : DTS
Format/Info : Digital Theater Systems
Duration : 1mn 10s
Bit rate : 755 Kbps
Bit depth : 24 bits
Stream size : 6.35 MiB (8%)
Results 1 to 1 of 1
Convert BD audio from DTS-HD to Dolby 5.1 AC3 without video?
By agent154 in forum AudioReplies: 1Last Post: 5th Apr 2012, 17:19 -
Audio options AC3 vs DTS
By jamesj84 in forum AudioReplies: 1Last Post: 7th Mar 2012, 20:25 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 08:17 -
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 10:56 -
How to convert DTS audio to AC3?
By Henderson in forum AudioReplies: 1Last Post: 26th Jul 2007, 17:33
