I'm trying to find a guide that helps me burn blu ray movies on a DVD (only playable on a blu ray player) specifically on a mac
I remember doing this a while ago, but i can't seem to find the article. Anyways when I did it back in the day, I did it on a windows computer, but this time I'm trying to do it on a mac.
any help will be appreciated, thanks!
	Roxio Toast Titanium with the additional High-Def/Blu-ray Disc Plug-in;
 or the Pro version, which includes the plug-in.
 There is also a tsMuxer for OS X 10.5, but that only authors the file structure, iirc. It took a few harder steps to create a UDF 2.5 disk image from that with the Terminal.
	Yes, Toast will burn to any media type that the drive supports, and the plug-in helps it author HD content (in the correct file system).
 (Note that Toast 9 requires the Toast 9 Plug-in, and Toast 10 requires the Toast 10 Plug-in. These plug-ins are different products.)"High Definition on DVD!
 You don't have a Blu-ray burner yet? No problem. With Toast 10 and the HD/BD plug-in you can burn high-def video content on standard DVD discs and play them back on your set-top Blu-ray Disc™ player! This is an innovative way to get between up to an hour of high-def content on affordable DVD media."
 (Note 2: I'd take the "up to an hour" skeptically. An hour would require a very low bitrate.)Last edited by Case; 29th Dec 2010 at 05:40.
	I have a saying that "Friends don't let friends use Roxio" so you have my deepest sympathies that this is your option on Mac.
 You should be aware that some BluRay players are much fussier than others about playing BluRay format on DVD media. Some will play just about anything. Others will require that the discs be authored in AVCHD format. Still others will only play discs authored like regular BluRay discs. And throw in that your player may be fussy if you use low quality DVD media, which in the USA means anything not made by Taiyo Yuden or Verbatim (everything is good except their cheap "Life" series). I's suggest doing some tests with RW discs first to see if your player is fussy. So in the end if you finally figure out what works on your BluRay player, please understand that such discs may or may not work on your friends' BluRay players.
  blu-ray for macBy scarlac in forum MacReplies: 14Last Post: 25th Aug 2010, 22:10
  Capturing Blu-ray onto a MacBy MrBlueSky in forum MacReplies: 5Last Post: 15th Dec 2009, 03:32
  Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a MacBy iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 17:50
  Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM DriBy donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
  Blu Ray Authoring on PPC MacBy whoisquilty in forum MacReplies: 5Last Post: 9th Jan 2008, 19:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
