Results 1 to 10 of 10
  1. I have recently bought "Sony Vegas Movie Studio HD Platinum 10". My video camera is HD. It is the "Samsung H200 full hd camera". When I download the video files from my camera, onto my computer, they are set to a MP4 format. When I try and import them to Sony Vegas, it imports, but when I press the play button, the video will play, but the audio cuts off, and cracks. I have tried converting it to WMV and AVI, but they still seem to have either the same issue, or similar. I have put in some codecs, but it still doesn't seem to work.
    How can I fix this? Please help me. Thank you.
    Apr 2004
    Miskatonic U
    Start with a mediainfo tree view of the file so you know what codec has been used for the audio (probably AAC) and what settings have been used.
    When you tried to encode it to something else, what did you use, and what settings did you use ?
    Does the file play correctly in WMP before conversion ?
    Read my blog here.
  3. Okay. Thanks for the mediainfo!
    And, when I tried to encode it to something else, I used "Hamster Free Video Converter". If I am sure what you mean on settings, I first used WMV, then tried AVI.
    And the file did not play correctly on WMP before conversion. It said I did not have the right codec, or the file format was not supported.
    Also, after I had converted it from MP4 to AVI, I imported it to Sony Vegas, and I could now hear the audio fine, but the video was slow and non-consistent.
    Apr 2004
    Miskatonic U
    Never heard of "Hamster Free Video Converter", but the name doesn't fill me with confidence (just visions of a small furry creature in a wheel). Try something like Xmedia Recode or Xvid4PSP in future.
    Try posting a copy of the tree view output here so we can see the file you are dealing with. Conversion to high quality HD WMV should work for Vegas. Unfortunately your computer specs are a little, well, vague. It may be that you simply don't have enough grunt to play back the file smoothly. Try this - click on Start, then right-click on Computer and select Properties. You should get a lot more details about your system - CPU, memory etc. - which will tell us if this is more likely to be a file or system problem.
    Read my blog here.
  5. Haha! I know! I uninstalled it, and now have been converting my MP4 files to WMV files, with a converting system that came with my camera (that we did not know it came with at first). :P And it works when I import it to Sony Vegas.
    You are right. When you said it works in Sony Vegas, when you convert it to WMV. So far, it works. I will let you know more as I continue.
    Also, I had checked the properties under computer. I saw some things that it said, but nothing really looked important to me, that would be useful.
    And I am sorry but, what is the "tree view"? I am a little confused.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Open your file, then select View (menu) -> Tree. Or Text. You can then highlight all the content and paste it into your post.
    When converting to WMV make sure you keep the bitrate high to maintain as much quality as possible during the re-encoding process.
    The information you want from the computer properties are these types of things
    Read my blog here.
  7. System
    Manufacturer: Gateway
    Model: DX4200-09
    Rating: 3.7 Windows Experience Index
    Processor: AMD Phenom(tm) 9100e Quad-Core Processor 1.80 GHz
    Memory (RAM): 4.00GB
    System Type: 64-bit Operating System
    Mar 2008
    Near the Beach
    I don't know if Vegas studio has the same options as Vegas pro. But try Options/Preferences and there Audio Device. Change it to Windows Classic Wave driver. Now listen to your video.
    If that doesn't work, try to export the sound as a normal Windows wave file. And put that wave file under your video, muting the aac file. Now try watching the video, good luck.
    Better to arrange the sound than to reencode the video first.
  9. Okay, I will try that! Lets see what happens! :P
    Thanks by the way!
    ______________________________
    After trying the options/preferences thing, it did not work. Now I think I am going to try the second solution you suggested.
  10. Okay, I have installed some codecs, and now my AVI files are going in, and working. It is a little slow though, when it is playing... O.o
    And I don't know if the audio works with the AVI files that I am now putting in, because I filmed them on mute.
