Have tried several time to join 2 identical MKV files(1 7gig the other 4gig) and keep getting 1 MKV file thats 12gig but only plays the first half of the movie then ends.
As The master (Baldrick) always says..... go back to an earlier version of MKVToolNix.
Ver 3.4 to 4.0 might work better than the newer versions.
Also, if that doesn't work you might try to pull out the streams and
individually re-insert them into the new MKV
Tony -
Hvent seen the final outcome from version 3.4.0 but i still get the warnings... Warning: matroska_reader: Could not keep the track UID 609880219 because it is already allocated for the new file.
Warning: matroska_reader: Could not keep the track UID 2715930044 because it is already allocated for the new file. -
Ok gave up on MKVToolNix and now trying Divx Plus Converter but now I have a new problem...
I have 2 different MKV's which i know for a fact are identical in every way,frame rate, aspect ratio ect.. ect... but for some reason it wont let me join them.
Every time i click combine all videos into one file the 2nd file has a ! next to it and when i click on it it says
this video will not be inclded in your final video because all files in combine mode must have the same resolution, frame rate,sample rate, bit-depth and channel count as the first file listed. BUT THEY ARE! ???
Joining video files in mkvmerge
By Zee530 in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2011, 15:29 -
How to edit an MKV with MKVMerge and it be successful?
By KingMatt in forum Video ConversionReplies: 1Last Post: 8th Sep 2011, 12:27 -
MKV 3D SideBySide with MKVMerge
By klode in forum Video ConversionReplies: 0Last Post: 12th Jun 2011, 08:54 -
making mkv using mkvmerge
By selv00201 in forum Video ConversionReplies: 8Last Post: 18th Apr 2011, 13:06 -
MKV corrupt? MKVmerge issue?
By TheParadox2 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2009, 11:05
