I'm running a Vizio 42" from a PC with a Radeon 9250. I've got a DVI->HDMI adapter on the card and then HDMI cable to the TV. If the TV is on when I boot the PC, I get a picture (very good one, in fact) on the TV. If I turn the TV off and back on, the TV says "No Signal". I can reboot the PC to get a picture again but TV just doesn't pick up the signal when it's turned on after the PC is booted up.
Any ideas?
I had the same problem.
I unplugged the power and replugged and did a re-scan of channels.
Hope it works. -
Not too sure, but clue may be found here:
http://www.hdmi.org/learningcenter/faq.aspx
In part, it states:
"HDMI supports two-way communication between the video source (such as a DVD player) and the DTV, enabling new functionality such as automatic configuration and one-touch play. By using HDMI, devices automatically deliver the most effective format (e.g 480p vs 720p, 16:9 vs 4:3) for the display that it is connected to - eliminating the need for the consumer to scroll through all the format options to guess what looks best."
I know there is a communications protocol between HDMI devices, but I haven't figured out all the quirks. Since you are using a DVI-to-HDMI converter, that may have something to do with it. (Thus, requiring you to turn on one device before the other.)
Turning computer off after capturing?
By justin81 in forum Capturing and VCRReplies: 4Last Post: 28th Mar 2011, 23:17 -
Toshiba Laptop Turning off...??? Help?
By Bearbegr in forum ComputerReplies: 10Last Post: 14th Aug 2008, 23:41 -
turning subtitles OFF
By john999 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2008, 13:05 -
turning up volume
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 27th Aug 2007, 01:03 -
turning on Subs by defult.
By MidasClaw in forum SubtitleReplies: 3Last Post: 24th Aug 2007, 21:14
