    Mar 2002
    sweden ][ stockholm
    I have a problem with droppes frames while capturing from vhs (10% )
    I'l have tryed to use som differnet comperssions and I donät notice any differns ( Huffyuv, mjpg, divx 5.0 and PICvideo) using virtual DUB.
    I have project to record a video from a vhs-tape to my computer then add music, text etc etc in premier.
    I saw the help text about ripping then editig, there it was recomended NOT to use divx encoder, and I understand that. I can slightly edit divx files (to laggy) on my computer.
    anyway, back to the problem!
    hardware info:
    AMD thuderbird 800@960mhz
    392mb pci-133 ram (3 128mb)
    maxtor 30gb with two partitions (dma is enabled)
    Geforce III Ti-200 64mb DDR ram
    SoundBlaster Live! 1024 value
    Hauppauge WinTV 878 card
    the tv card is connected to my vcr (samsung SV-631X stereo video)
    when im recording a music video or somehing with the card it dossen't drop a frame. but when I'l press play and starts to record with the card it drops frames (10%) I don't have a clue how it can be like that, could you help me ?
    (I live in sweden and are using PAL the connection between VCR and card is a composite cable)
    tnx alot !
    (I am a BIG NEWBIE on this kinde of technology)
    It's nice to be importtant, but it is moe important to be nice
    Jan 2002
    Australia
    If I understood correctlty (and I may not have!) you can capture OK from your TV tuner (in the VCR?) but not when you are playing a tape.
    In that case, your problem would seem to be with the tape player mechanism. Try cleaning the heads - low quality signals can cause drops - and try a different tape. Also, if your tape is wound too tighly, it may not be running at the correct speed - try fastforward to end then rewind.
    You should also check that the tracking is correct.
    Also, I have found sometimes (always?) that it is a good idea to start the tape playing a couple of seconds before you start the capture. It may be that the capture card need a little time to lock into the signal.
    If I'm wrong about your being able to capture OK from the TV tuner, then there are a million other things to check as well!!!!!! (On the PC side). There are many posts around with good suggestions there.
    Lycka till!
    Mar 2002
    sweden ][ stockholm
    you were correct!
    and thx I'l try that !
    tack!
