first of all I want to apologize if these issues have been addressed before. I spent the last 3 days googling for solutions, and nothing works.
I'm not sure what caused it in the first place, but recently every video I made with vdub would lose sound once I uploaded it to YouTube. it used to work perfectly fine before. snippets made from the same video are up on YouTube. so, I took the same MP4 file, cut a fragment out, using same specs, and suddenly it wouldn't upload properly.
I tried downloading some FLV-files from YouTube directly, then run them through vdub and put back on YouTube - same thing, no sound this time.
now, I can't figure out why it's happening. I tried running a newer version of vdub (1.9.10 currently). nothing changed. I did install a new set of codecs prior to all this (k-lite mega pack, can't remember which version, though).
I have lame AC3 installed so I figured I'd try converting the audio via the "Save to WAV" function. but every time I do it, vdub gives me an error message stating either:
or, when I check the "Direct stream copy" option:Code:Error initializing audio stream compression: The audio codec cannot compress the source audio to the desired format Check that the sampling rate and number of channels in the source is compatible with the selected compressed audio format.
I installed the AC3 ACM Decompresser (which I have no idea of how it's supposed to work), since most videos have 3-channel audio. still nothing.Code:Cannot convert audio: the source channel count is not supported (must be mono or stereo)
so, to summarize:
1) YouTube won't produce sound on my videos, made with vdub with the audio directly "stream-copied" (which were fine last month)
2) vdub won't save most files to WAV or AVI, rendering me helpless
I'm not the tech-savvy type, as you can tell, I have no idea what's causing this and how to fix it. I'd appreciate any help you can give. thanks in advance
Trouble with capture - ATI HD750/VDub
By TB Player in forum Capturing and VCRReplies: 10Last Post: 23rd Jan 2012, 17:37 -
Premiere Pro CS4 trouble working with mp4 clips
By LisaK2277 in forum MacReplies: 2Last Post: 18th May 2011, 09:52 -
[solved] VDub, Win7 x64, Multiple passes?
By Keeyu in forum EditingReplies: 2Last Post: 12th Jan 2011, 04:01 -
Multiple issues with DVDStyler (Including menus not working)
By Xmetalfanx in forum Authoring (DVD)Replies: 3Last Post: 6th Mar 2010, 01:27 -
Not Working?? Capture with BFG 7800GTX and vDub
By DW in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2008, 15:12
