    Jul 2004
    Italy
    Hello
    I have these 2 files with the extensions in the title
    what is the best software to use to create a dvd? I tried with img burn but I am not sure that the procedure is correct
    first of all the two files must be "build" in a temporary folder and then write when both are .iso: is that correct? any alternative software?
    thanks a lot/Fabio
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    ImgBurn doesn't create DVDs....it just burns them.
    You need something like DVDFlick or similar program to convert your files to DVD standard and create a DVD....then burn that with ImgBurn.
    Jul 2004
    Italy
    Thank you
    don't understand why but DVD flick doesn't start and I am forced to restart the pc
    any valid alternative to dvd flick?
    thanks/Fabio
    Oct 2007
    avstodvd (free), convertxtodvd (not free)
