If I add subtitles to MKV file using MKVToolnix can I then remove them, edit them, resynchronize them or I have to make SURE the subs are perfect before I put them into the container?
Results 1 to 9 of 9
You can add them, and later remove them if they are not correct, then replace them with a better version. Repeat as necessary.
Many programs and devices that accept MKVs will also accept external SRTs . If that is the case with your usage the best bet would be to include an internal one and for any updates to the SRT include it as an external SRT. Just make sure it has the same name as the the MKV and it is in the same folder. For external ones you can change them whenever you want without going back to the MKV.
Tony -
I just came across a media player that won't play external srt on mkv files.
Do you know how long the process takes? -
Don't know what you mean by how long it takes. I have both the WD and Seagate media players. Both play externals so do most of my computer video players . To change timing of SRTs most programs will do that in under a minute. To change the text, you can use subtitle programs or even use the windows notebook to make changes. Making changes in a SRT is usually also very quick. And if all else fails, with external SRTs you can always download an SRT from one of the many online sites.
Tony -
Adding permanent subtitles to MKV file
By karpad in forum SubtitleReplies: 5Last Post: 31st Mar 2012, 21:06 -
Adding subtitles to MKV container via mkvtoolnix
By subbin in forum EditingReplies: 1Last Post: 30th Jun 2011, 03:28 -
Adding working subtitles to .mkv files
By Yoven in forum Video ConversionReplies: 1Last Post: 10th Oct 2010, 13:43 -
Adding .ass subtitles to a MKV file using mkvmerge
By tyson123g in forum SubtitleReplies: 14Last Post: 13th May 2010, 01:03 -
Adding hardcoded subtitles to MP4 for playback on PS3 (original source MKV)
By linksys in forum SubtitleReplies: 2Last Post: 19th Dec 2008, 15:12
