I am looking into getting a SSD drive from my older Dell pc....And using it for a boot drive and to run my programs faster. It has a sata hard drive right now. Do I have to check and see if my CPU or motherboard can use a SSD? What about ram?
I've heard of some older versions of Windows needing specific drivers to be installed to get SSDs to work, but I haven't heard of any CPU/motherboard restrictions. RAM shouldn't even be a factor. However, note that there is SATA 1.0, 2.0 and 3.0 and SSDs are either 2.0 or 3.0. If your PC is old enough that it only supports 1.0, I think that is going to be a problem.
It is also best to use an O/S that supports "TRIM" and an SSD that has the TRIM function. Otherwise you have to manually use tools to wipe out the previously used areas on the disk or you will lose capacity over time. Windows 7 is the only Windows o/s to fully support SSD drives with TRIM.
http://en.wikipedia.org/wiki/TRIM
How to keep my ssd drive from filling up
By neworldman in forum ComputerReplies: 3Last Post: 29th Nov 2011, 03:33 -
SSD drive and mechanical drive
By astro4travel in forum ComputerReplies: 0Last Post: 29th Jun 2011, 20:44 -
SSD drive worth the effort?
By neworldman in forum ComputerReplies: 19Last Post: 31st Jul 2010, 00:22 -
Can't get e-sata to work
By DarrellS in forum ComputerReplies: 28Last Post: 31st Jan 2009, 11:35 -
anyone here using as SSD drive yet?
By lordhutt in forum ComputerReplies: 23Last Post: 13th Oct 2008, 10:16
