Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Dec 2010
    I have created beautiful rips of couple blu ray movies. I used the Ipod setting as the export. iTunes will open and play the movie fine, but if I try to sync it to the Ipod it says it is not the correct format. I have tried several other programs but they all drop the resolution to much. I use the iPod/iTouch to play the movies on our TV and I want comparable quality to the Blu Ray, disks space is not an issue. Has anyone else had issues syncing the Ripbot mp4 to their iPod/iTouch??
  2. iTunes won't sync your mp4 probably due to too high resolution.
    http://www.apple.com/ipodtouch/specs.html
    Dec 2010
    I am confused, doesn't using the iPod setting in Ripbot lower the resolution so it should load to an iPod? Otherwise what good is an iPod setting.
    Can I change the resolution in Ripbot to get it to 720p, 30 frames per second so I can sync it to the device?
    What is the resolution of the movies I download from iTunes, they look very clear when I play them?
    Thank you for responding!
