Hello,
I have Canon VIXIA HF M30 Dual Flash Memory Camcorder.
I am getting the message "task in progress do not disconnect" every time I switch off my Cam. It stays for 3 seconds.
Is it normal or there is something wrong with my camcorder. My camcorder is not connected to Computer not I have any SD card . I am using internal 8GB memory.
Please help.
not sure if this will help
check the manual under additional informationTask in progress. Do not disconnect the power source.
- The camcorder is updating the memory. Wait until the operation ends and do not disconnect
the compact power adapter or remove the battery pack.
Can I use a 30Mbps memory card on a Canon Vixia HF S20 camcorder?
By Willet Vary in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 19th Jan 2011, 00:59 -
I need help with Canon Vixia HF R10 HD Camcorder
By Nugrl in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Dec 2010, 14:40 -
Please help: Canon VIXIA HF M30 Dual Flash Memory Camcorder
By Benchmark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Jun 2010, 20:18 -
Is Vixia HF M30 a good choice?
By twister6 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Jun 2010, 01:32 -
Canon Vixia HFS100 Specials HD Camcorder Review
By tomrussel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th May 2009, 14:09
