ok hopefully simple for someone here. I have tunebite 7 and i need to use the capture wizard. No problems with that. But when i play the movie i want to record using screen capture, the capture wizard disappears into the background. My problem is when the movie is completed, in order to get back the capture wizard to stop the screen recording i need to use alt tab button to find screen capture and then hit the stop button. My problem is that that 5-10 seconds when i do this, i also record the screen movements, i don't want this. Is there a way around this. I tried several recording, and cannot figure this out. Thanks all.
I'm guessing this movie is not on a DVD....but a copy protected file of some sort?
yes capturing a movie to add to my ipod to watch later on. I just don't like to see the end part of me moving the mouse in order to stop the recording. Thanks
Is there a capture utility like tunebite that will capture 5.1 audio?
By yoda313 in forum Capturing and VCRReplies: 5Last Post: 18th Dec 2015, 02:45 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
Tunebite vs SoundTaxi
By weavejenn in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2009, 04:19 -
Tunebite video settings..is anyone out there familar with tunebite?
By cduval04 in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2007, 16:41 -
Screen Capture
By RoadRunner01 in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2007, 07:31
