Results 1 to 9 of 9
I,ve had very good luck with Format Factory (free). But make sure you stick very close to original MKV settings. I use Dvix, 720x480 for video size, 2400 for bit rate, same frame rate as original (usually 23.976)(very important), same aspect ratio as original. Audio you can pretty much set what ever you want.
With VirtualDub I go from .mkv to .avi(XviDHD), but you need the DirectShowInputDriver in the VDub-plugins folder
written by patto6 -
I've never tried Format Factory, so I can't comment on it, but I've had decent results with XMedia Recode (also free).
I wanted to find a solution to convert using the VirtualDub or avidemux but I tried different things and I did not succeed ;/
convertxtodvd can do this conversion, but can only convert to dvd format. -
I do it like this: in VDub: open file, select the .mkv, then audio, full processing mode, then again audio: compression (AC3 ACM codec and
Fraunhofer MP3 Codec Pro have to be installed on your system), mostly I choose AC3 ACM 224 kBit/s 4800 Hz Stereo 28 kB/s.
Then in the Video tab : compression, XviD MPEG 4 Codec. Then File, Save as AVI. This way you get a XvidHD.avi withe the same
resolution as the .mkv. I had to do this because suddenly my WD TV won't play .mkv anymore on my Samsung HDTV via HDMI.written by patto6
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Converting .mkv to .avi subtitle problems?
By oxadiba in forum SubtitleReplies: 1Last Post: 9th Apr 2011, 09:45 -
Problems with converting mkv(h. 264) to avi
By sgbd in forum Video ConversionReplies: 7Last Post: 18th Nov 2010, 11:10 -
Problems with converting MKV to AVI
By Sayuri in forum Video ConversionReplies: 25Last Post: 1st May 2010, 07:57 -
Problems converting mkv to avi properly. (subs)
By biogenesis in forum Video ConversionReplies: 14Last Post: 26th Apr 2009, 23:31
